Piece of string questions...
Evenin' all. I'm finally (!) getting on to the Poland popped drive side oil seal, self imposed deadline, RT 225 rebuild. So here's some questions, any thoughts would be gratefully received...
(1) - I've replaced the blown drive side oil seal with a Casa double lipped Viton item. The oil seal was a git to fit & stood proud of the bearing retaining plate face. Fully pulling the crank in resulted in a locked crank, something I've NEVER! seen in decades of engine building, the only new bits in the mix being the oil seal & gasket.... So I rotated the retaining plate/oil seal in a vice which pulled the oil seal in a bit further, it is still proud of the retaining plate face. At this point I walked away without refitting the crank, so this may be a tad premature, as things may be actually be sussed, but has any one out there experienced anything similar...?
(2) - I'm swapping out the GP kickstart ramped endplate for a sidecasing ramped LI etc ramped unit & need to transfer the layshaft bearing race. I've forgotten how to do this, is it just a case of whacking it out with a suitably sized socket & ditto for the refit?
(3) - Something I've NEVER considered doing... In case time runs out on me, but why not? Is it really a NO! NO! NO! on reusing good nick ali/metal head & base gaskets that were well within squish tolerance...?
(4) - Now the real 'how long is a bit of string?' question...
I've got a close5 AF gearbox that I'm so up for fitting while the engine is as naked as it ever could be. The destructions related talk of 'relieving', 'filing', 'angle grinding' etc have got me traumatised before I've even started... I won't let this stop me, but if anyone out there has any hints/ideas/prayers or 'hacks' (I SO dislike the modern world!) that might help?
With many thanks!
With many thanks!
