Con-Fused
Finally got the lights, brake light, horn, working last night but when I switched from high beam to dip or the other way round it would blow the fuse.
Today it now blows the fuse if I try to switch on the lights via ignition switch. Although the speedo, horn, brake light will work (until I turn the ignition switch)
I’ve looked over the connections and everything seems insulated correctly.
Any ideas?
Any ideas?
