Piston replacement
Hi, I've just removed my piston from my SIL barrel and it looks like a standard 3 ring Mahle(?) piston. The rings need replacing but the piston to bore clearance is OK. I was wondering whether to replace the piston with a better one so was after recommendations? Or to just replace the rings. Though I have read that if I replace the rings not to bother fitting the bottom ring?
