Head set clamp
Posted:
Sun Oct 17, 2021 2:18 pm
by a-teamlambretta
Just assembling my head set using a new mb clamp... Series 3 none chrome ring origional forks and head set just a new clamp. Head set is touching the legsheilds but the clamp needs to go down another 6 mm or so to locate the pinch bolt... Are repo clamp known to need fettling?
Cheers simon
Re: Head set clamp
Posted:
Sun Oct 17, 2021 2:43 pm
by Dicky
Are you building up from scratch or just replacing the clamp? Do you have the original to compare
Re: Head set clamp
Posted:
Sun Oct 17, 2021 3:01 pm
by a-teamlambretta
Dicky wrote:Are you building up from scratch or just replacing the clamp? Do you have the original to compare
From scatch... Late jet only difference is the new clamp and italian headset, dont have the origional clamp
Cheers simon
Re: Head set clamp
Posted:
by dickie
You haven't fitted the clamp on the wrong side of the headset casting have you? I've done that before and blamed parts before blushing.
Re: Head set clamp
Posted:
Sun Oct 17, 2021 3:09 pm
by a-teamlambretta
dickie wrote:You haven't fitted the clamp on the wrong side of the headset casting have you? I've done that before and blamed parts before blushing.
Nope....clamp on top...frame forks and legsheilds are origional as it came from the factory... The only difference is the new clamp and im using an italian headset set
Re: Head set clamp
Posted:
Sun Oct 17, 2021 3:11 pm
by a-teamlambretta
Ive just tried with the clamp fitted underneath.. The pinch bolt lines up but the there is too big a gap between the legsheilds and headset
Re: Head set clamp
Posted:
Sun Oct 17, 2021 3:48 pm
by dickie
You're right off course.....I made the opposite mistake.
I'll get my coat
Re: Head set clamp
Posted:
Sun Oct 17, 2021 3:50 pm
by dickie
Will the legshields go lower?
Re: Head set clamp
Posted:
Sun Oct 17, 2021 4:01 pm
by a-teamlambretta
dickie wrote:Will the legshields go lower?
Nope...legsheilds are on as low as they will go...any lower and the steering lock plate willbe exposed... As they are now, the upper edge of the legsheilds are sitting more or less flush with the top edge of the steering lock plate... It all looks pretty good apart from the slot on the forks and tge pinch bolt are a good 6 or 7mm out of line... I could slot a bit more out of the forks but the bolt would then be very close to the top edge of the fork tube
Re: Head set clamp
Posted:
Sun Oct 17, 2021 7:41 pm
by Freight10
Hi, no idea if you've changed the fork bearings during your build but I made a schoolboy error recently with mine, I put the Fork Steering Lower Bearing Dust Cover upside down, it looked right but had exactly the same problem your having, took me an age to work out where I had gone wrong, I only really found it cos I literally stripped the whole lot out again and started from scratch.. just a thought if you've done the bearings.
Re: Head set clamp
Posted:
Sun Oct 17, 2021 8:16 pm
by a-teamlambretta
Freight10 wrote:Hi, no idea if you've changed the fork bearings during your build but I made a schoolboy error recently with mine, I put the Fork Steering Lower Bearing Dust Cover upside down, it looked right but had exactly the same problem your having, took me an age to work out where I had gone wrong, I only really found it cos I literally stripped the whole lot out again and started from scratch.. just a thought if you've done the bearings.
New bearings but didnt remove the dust cover.... Will try and borrow a genuine clamp to see if this is the issue
Re: Head set clamp
Posted:
Mon Oct 18, 2021 9:23 am
by roli150lam
you did remove the old lower bearing,you haven't installed the new bearing on top of the old?
Re: Head set clamp
Posted:
Mon Oct 18, 2021 3:33 pm
by a-teamlambretta
roli150lam wrote:you did remove the old lower bearing,you haven't installed the new bearing on top of the old?
Frame stripped and blasted, powder coated. I checked and fitted new bearings... Forks will be comming out tonight for another coat of looking at
Cheers Simon
Re: Head set clamp
Posted:
Thu Oct 21, 2021 1:10 pm
by Warkton Tornado No.1
Check the fork stem length.
I think that some forks are considerably shorter & my theory is that the ones I have came with a late SX200 which was probably assembled in Spain, but not as an Eibar/Spanish model.
I made up a distance piece/plug to sit atop the stem to allow clamping, but I will change the forks......eventually.
Re: Head set clamp
Posted:
Thu Oct 21, 2021 3:47 pm
by hullygully
+1 yup check your fork length Si
Re: Head set clamp
Posted:
Thu Oct 21, 2021 4:04 pm
hullygully wrote:+1 yup check your fork length Si
Thanks for that
& it jogged my memory further......bear with me!
Elsewhere on this Forum, currently much more knowledgeable people than I, are discussing the idiosyncrasies of Spanish production. So, I might not look too silly saying this (Gulp!) but I think the SX200 (F reg) I have was built with the aforementioned forks, non-chrome ring BUT with the lower TV headset.
The problem I had was as the result of me swapping the headset when the scoot was repainted/rebuilt for the 'correct' higher SX headset.
Re: Head set clamp
Posted:
Sun Oct 24, 2021 12:37 pm
by a-teamlambretta
Think ive sussed it....late jet forks, late jet frame a matching pair. Headset is italian none chrome ring.... So the Spanish and italian headsets are slightly different apart from tge obvious lights in the headset top....from a bit of reading up... Chrome ring headset Should fit?
Cheers simon
Re: Head set clamp
Posted:
Mon Oct 25, 2021 1:35 pm
a-teamlambretta wrote:Think ive sussed it....late jet forks, late jet frame a matching pair. Headset is italian none chrome ring.... So the Spanish and italian headsets are slightly different apart from tge obvious lights in the headset top....from a bit of reading up... Chrome ring headset Should fit?
Cheers simon
Personally, I think the combination of the lower (chrome ring type) headset without the chrome ring looks better.
So. Next question.....Presuming they are OEM, what legshields do you have? Are they 'arched' just below the headset or straight, please?
Re: Head set clamp
Posted:
Mon Oct 25, 2021 2:21 pm
by a-teamlambretta
Warkton Tornado No.1 wrote:a-teamlambretta wrote:Think ive sussed it....late jet forks, late jet frame a matching pair. Headset is italian none chrome ring.... So the Spanish and italian headsets are slightly different apart from tge obvious lights in the headset top....from a bit of reading up... Chrome ring headset Should fit?
Cheers simon
Both are oem, its just the clamp and headset that are replacements. The legsheilds have a slight arch. Ive slotted out the brackets on the legsheilds and managed to get them to sit a little lower.. Also trimmed a couple of mm off the legsheilds at the top, so now fitting quite well and no need to enlarge the notch in the fork tube.
Cheers Simon
