Drive side seal test
PostPosted: Sun Sep 28, 2014 6:31 pm
by jonno
Am I right in remembering that to test if the drive side seal has gone you put a cloth over the exhaust and it should stop if every thing's ok?Lashed up a leak test but a couple of leaks put the kaibosh on that method,them being in some welding.There is no other explanation for loss of gearbox oil is there?Rear hub seal is ok.
Re: Drive side seal test
PostPosted: Sun Sep 28, 2014 6:37 pm
by torquewrench
The drive side seal failures I have seen have been accompanied by clouds of white smoke coming out of the exhaust.
PostPosted: Sun Sep 28, 2014 8:10 pm
by jonno
Some peeps have said that in the past but checked oil level and ok.I use 4% fully synth,and when warmed up smoke isnt excessive
PostPosted: Sun Sep 28, 2014 8:15 pm
by Knowledge
Jonno,
It is usually a distinctive white smoke, and plenty of it, to the point that your mates would prefer that you rode at the back.
What symptoms are you trying to eradicate?
Martin
PostPosted: Sun Sep 28, 2014 9:51 pm
by coaster
Knowledge wrote:Jonno,
It doesn't smell like 2 stroke oil either...in fact it tends to stink :?
PostPosted: Sun Sep 28, 2014 10:18 pm
by jonno
Hi knowledge,just trying to find out where half my gearbox oil went.Dont want to strip it down till end of sprint season.Sure I put right amount in pretty ocd about that.Think Ill refill see how it goes.Ill block the exhaust to test it ;)
PostPosted: Mon Sep 29, 2014 7:13 am
by Mel K
A quick covering of your exhaust with your hand is ok for checking an exhaust leak but I wouldn't block the exhaust to check for oil seal leaks , the build up of pressure you'd create has to go somewhere and you could end up blowing an oil seal in the process . Just my thoughts on the subject .
PostPosted: Mon Sep 29, 2014 8:36 pm
by Norfolk
When my drive side seal failed symptoms were engine ran just as expected for approx 5 miles , then god help anyone following me white smoke in excess from the exhaust was a understatement ! The gearbox was found to be completely devoid of any oil! Tried an aftermarket seal expander additive to cure the problem which was a waste of time ! !
PostPosted: Tue Sep 30, 2014 7:55 am
by Digger
Yes indeed - you simply can not mistake a drive side oil seal failure smoke cloud for anything else. :D
