KNOCKING FRONT HUB BACKPLATE.
Posted:
Thu Apr 14, 2022 3:50 pm
by kevspeed
Anybody know if there is a press on bush available to fit over the 'knuckle' that slots into the front hub backplate to stop it knocking?
Re: KNOCKING FRONT HUB BACKPLATE.
Posted:
Thu Apr 14, 2022 6:33 pm
by duncan1958
I cut a slither from the side of a can of pop.
Seems to do the job.
Posted:
Fri Apr 15, 2022 8:27 pm
by Wack
Tighten the axle inner nuts real tight then you won't get the knocking.
Posted:
Sat Apr 16, 2022 9:49 pm
by L111amo
A bit of rubber fuel pipe heated up. Does the trick
Posted:
Mon Apr 18, 2022 12:01 pm
by kevspeed
Hi all,i managed t get a small peice of copper pipe into the gap,it seems ok for now fingers crossed!
