Indian Stator plates
Posted:
Thu Jul 14, 2022 8:21 pm
by Leotech
Fitted a new 12v electronic stator, got 60 miles out of it before it was goosed!
Is this a record.
Had it in the workshop a while so cant even remember where I bought it to send back.
I suppose I can solder on a new LT coil.
Re: Indian Stator plates
Posted:
Fri Jul 15, 2022 12:57 am
by coaster
ALL stators especially Indian ones benefit from some 're-enforcememt prior to use. The earth tag rivit needs additional peening as they come lose. All soldered joints need careful examination and re-soldered if nesessary and then mix up some Araldite and put a blob on the earth tag and all soldered joints. Also use it to anchor any wires that can move to something solid. glue the pickup bolt too
Posted:
Fri Jul 15, 2022 1:55 am
by Fast n Furious
Posted:
Fri Jul 15, 2022 6:09 am
by Cgt75b
I’ve had a scooter restorations Indian 12 volt kit on my scooter for longer than I can remember without any trouble at all, we will see if the scootronics one is as good, time will tell.
Nothing wrong with Indian.
Other well known brands fail with great regularity don’t be fooled by the name plus brand.
Cgt75b.
Posted:
Fri Jul 15, 2022 9:19 am
by Leotech
Cgt75b wrote:I’ve had a scooter restorations Indian 12 volt kit on my scooter for longer than I can remember without any trouble at all, we will see if the scootronics one is as good, time will tell.
Cgt75b.
So have I, I have some Indian stators that are probably 20 years old. I have also had the latest greatest ignition products fail also.
I was just making a bit of a fun post about the 60 miles more than a serious product review.
Posted:
Fri Jul 15, 2022 3:03 pm
by hullygully
you got that far......................
Posted:
Fri Jul 15, 2022 7:06 pm
by Fast n Furious
Yeah.... but at least it was within pushable distance back to the workshop
Posted:
Fri Jul 15, 2022 10:02 pm
by Rich Oswald
My Indian stator has been on my GP since at least 1998.
Posted:
Fri Jul 15, 2022 11:42 pm
by Warkton Tornado No.1
If we're playing 'Stator Top Trumps' I've never had an OEM Innocenti stator fail. Considering that they are usually swapped out with the excuse of 'reliability'
the only component known to actually fail is the condenser & even that is rarely terminal as far as engine failing to run.....
Posted:
Sat Jul 23, 2022 1:06 pm
by Adam_Winstone
Agreed WT1 but I've noted how quickly some of the available replacement condensors fail (!). You're absolutely right that the Ducati OEM systems are typically VERY reliable and it is a shame that the aftermarket parts to fix them are not so good.
Posted:
Sat Jul 23, 2022 2:29 pm
by Fast n Furious
The problem with contact breaker stators is that there is very little market demand for any spares. The replacement condensors that are available are usually new old stock units that have been sat on a shelf somewhere for decades where the internal electrolyte has evaporated away making them useless. This is a problem for all classic bikes.
Posted:
Tue Jul 26, 2022 9:28 am
by Leotech
Adam_Winstone wrote:Agreed WT1 but I've noted how quickly some of the available replacement condensors fail (!). You're absolutely right that the Ducati OEM systems are typically VERY reliable and it is a shame that the aftermarket parts to fix them are not so good.
I was fixing a mates 150 Super Vespa, It was on points, I had to fit a new condenser. It also had issues with the lights, by the time I'd kicked it and ran it on and off most of the morning checking the lights etc. it stopped starting again.
Looked at loads of things, It was the new condenser i'd only fitted the afternoon before!
Posted:
Thu Jul 28, 2022 11:41 pm
by Adam_Winstone
Yep, I too have fitted replacement condensors, soldering correctly and not overheating for a prolonged period, only to find that the condensor fails in a very short period. Replacing in the same manner, with a decent replacement, has then been reliable for years!
Posted:
Fri Jul 29, 2022 5:10 am
by dickie
If we could find out the characteristics of original condensers: capacitance, voltage (less important as long as you stay above that value) and dimensions (just measure obviously), then maybe there are modern alternatives rather than NOS.
Certainly, there are modern alternatives but likely not with the same dimensions so would probably need to be fitted externally.
Anyone know the capacitance in particular?
Posted:
Fri Jul 29, 2022 8:06 pm
dickie wrote:If we could find out the characteristics of original condensers: capacitance, voltage (less important as long as you stay above that value) and dimensions (just measure obviously), then maybe there are modern alternatives rather than NOS.
It looks like you've volunteered
but I will try & find out the capacitance.
TBH we used to run external capacitors for their reliability in racing. I think mine were from a Ford Corsair....
Posted:
Sat Jul 30, 2022 12:02 am
by coaster
I might be a lone voice here, but I don't have a very high regard for points ignition. properly timed and gapped they are fine but the performance starts to drop off from the moment you fire the engine up. Not immediately obvious but notiable after a thousand miles or so. Then its off with the rear runner and cowl and performing keyhole surgery to adjust them through the window in the flywheel. I had a wire break off the capacitor once which was a right pain bodging back on in a layby. Not just Lambrettas, countless minis, Cortinas, Vivas all required the points to be replaced at approx 3k miles. I'd rather strengthen an electronic stator (easily done) and carry a cheap indian CDI as a backup/test/get you home item
Posted:
Sat Jul 30, 2022 1:56 am
by Fast n Furious
Generally, the condenser value for any magneto ignition will be between 0.1-0.3uF and have a working voltage in excess of 300V.
On a single cylinder magneto, the primary current flow will always be in the same direction every time the points open. So, if the contacts show signs of pitting (a tip on one side and a corresponding pit on the other), the capacitance value needs to be adjusted. If the contact material transfers from the negative to the positive point, the condenser capacitance should be increased. If the transfer is from the positive to the negative point, condenser capacitance should be decreased.
Posted:
Sun Jul 31, 2022 10:19 am
by Chadley
I use EasyCap CU/220s as replacements for condensers on points stators:
http://brightsparkmagnetos.com/easycap/index.htm
After I experienced intermittent ignition drop-outs when hot, I replaced the original Ducati condenser with an EasyCap. No further issues (well not ignition related!) since fitting it about four years ago. It requires adapting the generic PCB to suit and is not the cheapest item. I measured the capacitance of on original Ducato condenser and found it to be ~440nF but the EasyCap 220nF seems to work well for me.
Posted:
Mon Aug 01, 2022 9:46 pm
Sorry for the delay:
As far as the OEM physical sizes, I checked out an old OEM Ducati capacitor:
Nominal diameter: 13 mm
Nominal overall metal body height: 35 mm
Nominal protruding metal body from mounting face: 24 mm
