Series 2 Front Sprocket Spring and Cap
I have managed to damage the Front Sprocket Spring Cap on my Series 2. It is currently fitted with the shorter spring and cap as detailed in Stickys manual. I cant find a replacement so was thinking it may be easier to go with the later spring and cap, bearing in mind this is taller are there any issues fitting this inside the Series 2 side case ?
