Press horn, lights go out!
PostPosted: Fri Feb 10, 2023 6:15 pm
by Revvers
Hello all. As the title says, when I press the horn on my ‘65 Li Special, both the rear and front lights go out. It’s a non battery model. Any ideas please??
Re: Press horn, lights go out!
PostPosted: Fri Feb 10, 2023 8:06 pm
by Toddy
I would say you have a bad earth somewhere have you checked anything yet ?
PostPosted: Fri Feb 10, 2023 8:24 pm
by Revvers
No I haven’t. I’m thinking of taking the headset off on Sunday and hoping there’s something obvious!
PostPosted: Fri Feb 10, 2023 8:27 pm
by Toddy
I would see if anything’s popped out or touching anything
PostPosted: Fri Feb 10, 2023 8:32 pm
by Revvers
Will do. Cheers. Just checking for the Mot and noticed it
PostPosted: Fri Feb 10, 2023 8:34 pm
by Toddy
Do the lights go completely out or just dimmer ?
PostPosted: Fri Feb 10, 2023 8:55 pm
by Fast n Furious
Horns do pull a lot of current and will dim the lights on batteryless setups.
If it's killing the lights and not actually sounding off, then the horn is, in effect, creating a short circuit.
Are you certain that the horn is one for an AC model? ( if you are unsure, then just connect it across a 12V battery to find out)
Try a substitute horn!
PostPosted: Sat Feb 11, 2023 8:26 am
by Revvers
Toddy wrote:Do the lights go completely out or just dimmer ?
They go completely out
PostPosted: Sat Feb 11, 2023 8:27 am
by Revvers
Fast n Furious wrote:Horns do pull a lot of current and will dim the lights on batteryless setups.
It’s the original horn and switch and the lights go completely out
PostPosted: Sun Feb 12, 2023 6:46 pm
by Revvers
I’ve had a look at my wiring. Sorry, I was wrong in my initial post, the lights don’t go completely out they dim quite a bit. I cannot see any breaks and the earths look ok. When I press the horn, the headlamp dims and the back light is almost out. The headlamp is a Jockeys one and I disconnected that to see if that was the issue but the rear lamp still dimmed.
PostPosted: Sun Feb 12, 2023 7:29 pm
by Fast n Furious
Does the horn work when the lights are switched off?
PostPosted: Sun Feb 12, 2023 7:58 pm
by Revvers
Fast n Furious wrote:Does the horn work when the lights are switched off?
Yes it does
PostPosted: Mon Feb 13, 2023 3:01 am
by Fast n Furious
It's normal for the lights to dim when using the horn on an AC setup, especially at low revs.
