What do you make of this seizure?
Running in an iron 175. Only done 80 miles, or so. Classic case of got stuck on a long straight road were it was difficult to go up and down the gears. Anyway, I had a soft seize and left it for 5 minutes. Kicked it over and started to limp home. One more soft seize before what I thought was a proper hard seize - kickstart absolute solid, even an hour or so later.
This morning, fearing that I had a melted piston all over my barrel, I poured some two stroke oil down the plug hole and left
After coming back to it late this afternoon, it freed off with little effort. On taking the barrel off, I find virtually no marks on the piston, both ring pegs in place but these “ring marks” around the barrel which would appear to me to have been made by the piston rings.
I am going to clean the barrel up gently with a bit of wet and dry and put it all back together. I don’t have the carb properly set up yet so I am proposing to richen it up throughout the range whilst I do some more systematic plug colour checks.
I have never had a seize like this before - locked solid but no evidence of a melted piston. It’s almost like the piston rings stuck in the bore but not the piston.
Has anyone any ideas what may have happened and why? There was two stroke oil in the petrol.
