Studs protruding over gearbox endplate nuts
Hiya, just finished a gearbox rebuild - all went well
however I used one of MB's longer endplate stud gearbox kits. The longer end went into the cases lovely and its nice to have the extra support in the ally however the shorter length side protrudes over the nut (after torqueing up) about 3mm. Worried that its going to catch my chain - could I get around the problem by using a bigger shim under the clutch basket/spider? cheers Paul
https://www.lambrettaspares.com/spares/ ... 0631k.html
