Checking a 12v Battery holds its charge.
I know that even healthy new batteries will discharge over a period of time if not in use.
My Series 2 with indicators has a 12v SIP battery. The positive terminal has two connectors one for the indicators and the other to the loom. The negative is, of course, just to earth.
I have charged the battery up and I am now getting 12.39 volts showing on a multimeter between the positive and negative. I won’t be using the scooter for the next month, or so. I am planning to just measure the voltage every few days to see how much charge it loses.
Is 12.39 volts acceptable and how much should an unused battery (but one that is wired up on the scooter) lose over the next month?
