Exhaust Fitting Problems
Postby Littlewheels » Tue Jan 28, 2025 9:51 pm
I'm trying to fit a Casa standard exhaust to my series 3 TV175 but it's a very poor fit.
I can get it on the manifold & front studs ok but then it sits too high near the frame strut so it rubs/touches on the rear footboard. Also the tailpipe is much too high to the point where the only way it will fit is if i apply force? It also sits too close to the chain case level plug so that it would be impossible to remove with the exhaust on.
I have tried bending the front bracket slightly and bending the manifold so it sits lower but with little success :?
I am now considering buying a different manifold but before that thought i'd ask on here.
Last edited by Littlewheels on Tue Jan 28, 2025 11:19 pm, edited 2 times in total.
Littlewheels
Re: Exhaust Fitting Problems
Postby Storkfoot » Tue Jan 28, 2025 10:30 pm
I can’t speak for Casa exhausts as I have never tried one. But, in the last few years, I have had similar issues with a Scootopia and a Tutto Lambretta exhaust.
I tried to fit a complete Scootopia exhaust to my own s3 TV175. It was miles out. I ended up fitting the original u bend (I have no idea whether it was the original but it was the one it came from Italy with), with the kink in it, with the Scootopia silencer. That fitted okay.
I feel your pain.
Postby Scooterslag » Wed Jan 29, 2025 12:37 am
Such a lottery when it comes to fitting standard exhausts , I've collected quite a few standard U-bends as I find I have to chop and change them just to get a system to fit. I think most pipes I've had ( even OEM innocenti) over the years have required fettling and fitting. :roll: Paul
Postby Littlewheels » Wed Jan 29, 2025 1:53 pm
Well it's not just me then! :?
Anyone know which brand is the most reliable fit? :?:
Littlewheels
Postby ULC Soulagent » Wed Jan 29, 2025 2:53 pm
Littlewheels wrote:Well it's not just me then! :?
Gotta be either bgm or sip clubman ;)
ULC Soulagent
Postby dickie » Wed Jan 29, 2025 9:31 pm
I've had zero problems with:
BGM
Avanti ex box
Ancillotti.
Gori
Maybe I'm just lucky?
Postby gaz_powell » Mon Feb 03, 2025 9:25 pm
Just fitted a scootopia clubman to new build over the weekend and it fit well, ie cylinder/ubend to engine block clearance on cowlings etc... Even the tail pipe bracket went easy.... All good until i put the stand up!
Stand not going fully up catching on the lip of exhaust... Might be able to grind back edge of exhaust.... But had enough by then and left it next week.
Postby Storkfoot » Tue Feb 04, 2025 9:00 am
gaz_powell wrote:Just fitted a scootopia clubman to new build over the weekend and it fit well, ie cylinder/ubend to engine block clearance on cowlings etc... Even the tail pipe bracket went easy.... All good until i put the stand up!
Sometimes it’s the ubend being too long and pushing the silencer further out, Gaz. I’d suggest you have a look at that first, mate.
I’m referring to box exhausts in general. I’ve never tried a SIP clubman.
Postby gaz_powell » Wed Feb 05, 2025 12:29 am
Will do, cheers Paul
Getting back on it this weekend
Postby gaz_powell » Mon Feb 10, 2025 8:25 pm
Annoyingly, the u bends not pushing the main body out, so catching stand...
Then the u bend springs are mounted on top and bottom... So to one fouls the cowling.
And finally the tail pipe covers the jack stand casing hole...
Brilliant!
Got a 42mm AF at back of garage, will see what that fits like... Or maybe move to a SIP box
Postby superhooper » Thu Feb 13, 2025 9:18 am
As a note, you came usually slide the stand bar in from the rear
Regards
Roy
superhooper
Users browsing this forum: No registered users and 8 guests
