Storkfoot wrote:You can often get a sense of where the oil is coming from by studying the area around the bearing, seal and layshaft. If you have now wiped this area down, then your idea of running the engine on the stand seems worth a go. How quickly oil leaks show themselves, I’m unsure.
In the past, I have just fixed what I thought the problem was, put it all back together, and then taken the rub off a couple of hundred miles later. You’ll then see if you have fixed it by close inspection of the area around the bearing.
Oil leaking around the outside of the bearing is often a cause too.
In the past, I have just fixed what I thought the problem was, put it all back together, and then taken the hub off a couple of hundred miles later. You’ll then see if you have fixed it by close inspection of the area around the bearing.
coaster wrote:Has anyone tried gently presurising the chain case and checking for leaks with soapy water? obviously would need to blow in via a bung in the breather and maintain a positive air pressure as it will escape via the kickstart and other orifices....or as suggested, new oil seal, o ring and a smear of silicone around the bearing before fitting.
As Paul said, oil on the shoes is a common issue, Im just wondering if anyone has ever worn their rear shoes out
That brake cam looks like an Li type whereas your should be the GP variety, not realy an issue so long as the shoes match.
Check Steve Richards on Youtube (The Steel Weazel) he talking about the front but its all relevent to thye reav Part one deals with taking a file to the cam
https://www.youtube.com/watch?v=JboLYuGHC10
Warkton Tornado No.1 wrote:I am on record as stating that IMO the OEM layshafts are excellent, but if they have been subjected to abuse in their previous life, that may be impossible to detect visually. Personally, I cannot recall any failing.
The problem with such a component is that we can so easily overlook certain elements of the tasks that they are expected to do.
The surface upon which the oil seal lip runs needs lubrication, not only upon assembly. The surface needs to be of a certain roughness, not polished, for oil retention to ensure that the oil seal lip doesn’t wear out. The actual requirement for the surface finish will be as stated within any good seal manufacturer’s technical data if anybody would care to research it. However, if the surface is roughened up by common or garden green Scotchbrite, that should suffice.
I hope this information helps anybody unaware of the requirements for an oil seal to perform it’s function
Storkfoot wrote:Mark, I applaud your lathe work on the hub lining. I suspect all my hubs could do with that.
That said, I can’t quite get my head around what you have done regards the oil leak. In effect, you are putting it back together without having tried anything to rectify the leak. Is that right?
How badly are the brake pads impregnated with oil?
Paul
Storkfoot wrote:Thanks for the offer to machine my hubs, Mark. It’s a pity you aren’t a bit nearer![]()
Good luck.
Covboy wrote:I once turned my engine upside down on a bench to clean it and oil poured out from either the gear selector or clutch shaft and flowed straight into the rear hub contaminating the brake shoes . A classic example of a quick job turning into a bigger one !
LambrettaMarky wrote:Storkfoot wrote:Mark, I applaud your lathe work on the hub lining. I suspect all my hubs could do with that.
Paul
Thx Paul - if you get your hubs to me I'll happily do the same to yours.
So I haven't done anything as after a good de-grease and run up there is no sign of any leakage. I left it alone save a clean and new nylocs on the bearing plate. The oil must have come from somewhere and quite possibly it'll show after a good ride, but until I see it come through I'll hold fire.
Shoes were just a bit oily in general & Cam Lam said they were asbestos so they've gone in the bin now.
It all looks very good as you'd expect from a scooter with a few hundred miles on it really.
Will report back after a road test..
dickie wrote:LambrettaMarky wrote:Storkfoot wrote:Mark, I applaud your lathe work on the hub lining. I suspect all my hubs could do with that.
Paul
I once got a mate to machine my rear hub as it was very scored. The result was amazing, the best lambretta rear brake I've ever used by a country mile.
I guess the rough surface finish was the cause of the improvement. I've since ridden it after 3 or 4 more owners and about 10 years later and while it's still very good, it certainly isn't as good as it was for the first year or so after I built it.
Users browsing this forum: No registered users and 9 guests
