Lay Shaft O Ring
Well one reason for my poor rear brake was oil on the shoes/drum along with a well glazed braking surface on the drum liner. Not huge amounts, but enough to make it all oil soaked. I picked up a new Hub oil seal with the brake pads yesterday that I can access from the brake side, but was advised by Cam Lam that the likely cause may be the lay shaft O ring.
Now before I launch into disassembling the clutch side of the motor to get the lay shaft out, I plan to fit the new oil seal and run the motor in gear for a while (on the stand/jack still on the bench) so I can see what's going on.
Is this the best/only way to test the lay shaft O ring? I don't want to reassemble and then find out the same's happened to the new brake shoes?
I'll make a mandrel to mount the drum and emery cloth the brake surface to de-glaze it - that's the easy bit!
Any advice welcome and no doubt more special Lambretta specific tools will be needed.
Thanks Folks..
Thanks Folks..
