Rear Hub Bearing oil leak
I have a very slight oil leak between the outside of a rear bearing and the casing. The casing is an old Italian GP150 which, as an empty casing, I had owned for years before building a Casa 185 engine into it a couple of years ago. I have tried silicon sealant between the casing and the bearing but oil still weeps slightly through after a couple of hundred miles.
Is a bearing with a recess for an O ring likely to remedy this, with an O ring fitted of course?
https://www.lambrettaspares.com/mbp0712a.html
The link above is for an oversize bearing which, I presume, is not what I need as my bearing is still an interference fit in the casing.
