Vibration
Vibration
Postby Peterp » Fri Nov 06, 2026 8:22 pm
Hello all,
Has anyone had any vibration issues relating to the rear shocker? I’m unsure if I have vibration over the Lambretta acceptable limit.
Replaced the two engine mounts, cones and bolt. I have read that slackening the engine bolt back will reduce vibration.
Thanks to everyone who has helped me get on the road.
Peterp
Re: Vibration
Postby Warkton Tornado No.1 » Fri Nov 06, 2026 9:36 pm
Hi Pete.
Has the vibration come about since changing the engine mounts? In any case, painfully aware as we all must be that ‘aftermarket’ so often equates to ‘not-fit-for-market’ the - presumably new - mounts have to be the first suspect. BTW the trick of loosening the engine bolt can relieve stress in the mounts but should be done with the bike on the stand & the rear shock absorber nuts loosened too. It’s unlikely to make any difference in this instance & is probably only appropriate when the engine mount bolt has been tightened with the engine in situ whilst the frame has no shock absorber in place I.e. the frame sitting on the bump stop. Worth trying though :)
IME the OEM TV 175 is probably the SIII engine with the least vibration.
To summarise:
Are the mounts new? If so, where did you acquire them from? (A lot of mounts are sold as being suitable replacements but are not of the correct shore hardness & not even bonded. To achieve desired qualities, it is essential that certain stresses are built in by way of the bonding process)
Are the cones new & checked for angle & length? (There are two sorts for Lambretta large frames which differ in length plus possibly manufacturing errors if new)
Re: Vibration
Postby Storkfoot » Sat Nov 07, 2026 8:19 pm
Peter, how would you describe the vibration? Is it through the headset or through the seat? Or, elsewhere?
Re: Vibration
Postby Peterp » Sun Nov 08, 2026 11:47 am
Good morning both and anyone else who’s awake.
Mmm, the vibration seems to be the through the whole machine, in my ignorant opinion, quite harsh and hard.
It happens at a certain rev range, if I keep the speed down and the gear high it’s very smooth and a pleasure to ride.
I fitted Cambridge Lambretta mounts, the ones they recommended for ordinary riding. But, the first ones were absolutely crap, the bolt was sloppy and the finish was crappy too. They sent me a second set and I just fitted them.
I also fitted new cones and bolt.
I suppose it’s because of the new mounts etc is why I started to look at the rear shock.
But, I’m not sure. I understand balance etc at certain revs, we use to balance Cooper S cranks pistons flywheels etc.
When you get into 4th at about 35-40 it is smooth like above. After the two seizures I’m scared to open it up anymore past 50ish but wonder if I’ve got to avoid or get quickly through that spot and just live with it as a Lambretta trai.
Thanks again
Peterp
Re: Vibration
Postby Warkton Tornado No.1 » Mon Nov 09, 2026 12:36 am
I’ve just had a quick look on CamLam’s web-site on which they appear to stock only the BGM mounts. I have no experience of the BGM product but was of the belief that there was some consideration taken into bringing the product to market ie a serious attempt to replicate the OEM Innocenti mounts from an engineering perspective. The BGM mounts ought to be ‘fit for purpose’ but - this might just be me - the fact that initially you received mounts that you rejected does sound alarm bells :?
The only available new mounts I can vouch for in terms of suitability are genuine SIL. My preference has been the ‘solid through’ two hole SIL mounts which are highly prized. Although they transmit a tad more vibration, that is a worthwhile trade-off if handling is the priority. In any case, the chance of finding a pair nowadays is unlikely. However the SIL three hole ‘non solid through’ are IMO as good as OEM Innocenti though the finish tends to leave something to be desired. Logic dictates that as SIL acquired the Innocenti production plant, there was the likelihood that the mounts might be identical performers. The problem that may exist, though, is that the ‘rubber’ may have been modified in composition, bearing in mind the principal use on Indian roads.
Other mounts that I have took a punt on have only proved their worth as paperweights & been extracted within 10 miles use when vision has been restored.
I hate to say this, so don’t shoot the messenger. If you are content that - after a dubious false start - CamLam have sold you genuine BGM mounts & you’ve had two seizures, I would want to check you haven’t twisted the crankshaft…. :roll:
Re: Vibration
Postby Peterp » Mon Nov 09, 2026 12:40 pm
Mark, I’m puzzled by you only finding BGM mounts on CamLam. I bought SIL, £20.00. There advice was that these were the ones they recommended. But, on looking last night I see that they now recommended a different set.
The ones I bought are 1SS145 SIL. The others which tells of lower vibration is 1SS144 CASA.
Peterp
Re: Vibration
Postby Storkfoot » Mon Nov 09, 2026 10:53 pm
Yes, Cam Lam do sell the SIL ones. They have put the price up as I bought a couple of sets for £15 each last year. They don’t look great at all but they seem ok to me.
If you have ruled out engine mounts, components touching like toolbox and airbox, wheel rims, the seat itself and forks /headset then, as WT has said, the crank may be the culprit.
As I random side issue, my own standard TV175 produces vibrations through the seat for the first 5 or 10 miles. After which, it is absolutely fine. I’ve never got to the bottom of that.
Re: Vibration
Postby Peterp » Tue Nov 10, 2026 2:18 pm
Out of interest Paul, you say 5-10 miles of unusual vibration. Is this only at certain revs etc.
Keep off the throttle and low gears and it’s extremely smooth.
When I “gun it” briefly, 40-45 in top and I feel a hard harsh vibration. Perhaps it’s as it is, just me.
Not sure if I would want to take on long journeys,
Peterp
Re: Vibration
Postby Peterp » Tue Nov 10, 2026 2:29 pm
I meant to add, if I already haven’t done. When checking the timing, it was set at 19ish,,,, set it back to 17 with a light, put a larger TV200 main jet in and touch wood, no more seizures
But, I haven’t really completely reached the advised 1000 mile run in stage. So very apprehensive when throttling.
Should have listened to the wife, “ what do want a scooter for, your getting worse”.
Peterp
Re: Vibration
Postby Storkfoot » Tue Nov 10, 2026 2:51 pm
Peterp wrote:Out of interest Paul, you say 5-10 miles of unusual vibration. Is this only at certain revs etc.
Through the seat at mid range throttle openings. But, it goes quickly.
Digressing onto “running in” you should ride on B roads and go up and down the gears in short bursts. Do not be afraid to get it to wide open throttle but only for a few yards. Build it up as you go but, for a few hundred miles, avoid long straight roads. Taking a wrong turn onto a busy and fast dual carriageway can easily cause a seizure :oops:
Re: Vibration
Postby Warkton Tornado No.1 » Tue Nov 10, 2026 3:07 pm
As of my last & previous checks, CamLam neither display any engine mounts or reveal any other than the BGM on their website.
As for the vibration issue which is unquestionably not normal, it can only be resolved as the result of a tear-down to establish what is at issue. The best result would be that ‘peace of mind’ would be established. The worst scenario would be to just ignore it & the engine get wrecked & probably more. To be frank, I believe that many of us would have done so just as the result of two seizures!
Honestly, I completely empathise with the daunting prospect of wielding the spanners again to ‘un-build’ such a cherished scooter, but that is the unfortunate result of our trust in those ‘specialists’ selling products for which there is only some kind of arbitrary standard of quality & suitability.
There is some light at the end of the tunnel. Gradually, some products are improving. Whilst many may now acknowledge that the adoption of Indian electronic 12v ignitions for ‘reliability’ :lol: was a flawed reason, eventually reliable, European manufactured replacement set-ups are becoming available & even advanced by way of retardation. Ha! Excuse the pun :oops: Similarly, some crankshafts are available that are ‘bulletproof’ & the proof is written in Sticky’s kit book wherein he acknowledges that the SIP product stood up to extensive testing of the kits, probably being subjected to more stress than a crankshaft will ever endure in it’s lifetime.
However, none of us should be complacent & think anything new is automatically better. It’s not right that the unwary can buy front brake cables that fail, rear hub bearings that spit their balls out, loose gears that lose teeth on first start up or chain that is unfit from established dealers operative for over 50 years that are renowned for bringing cylinder kits to market capable of easily tripling the OEM engine output. In some countries this behaviour would be considered criminal…..
Re: Vibration
Postby Peterp » Tue Nov 10, 2026 5:29 pm
Cheers both, massive thanks.
I took a run out today, no issues, apart from frostbite. I’m going to keep on with the running in, today was all around our lanes and slight hills, up and down the gearbox.
It’s funny what you said Paul about taking a wrong turn onto a main road and you know what. That’s exactly in a way what happened, I was doing 45-50ish on a quickish A road for about 4miles when first one happened, second was 50mph for about 5-6 miles, light throttle but, obviously not good.
Ignorance on my part.
Anyway, as mentioned above, I’ll keep running it in as the manner you both suggest.
I will then just ride it run it make it work, not in a bad way but in a way that’s it’s designed.
If I have engine issues then I’ll remove strip and rebuild. In a nutshell, sod it, if it breaks then I’ll fix it.
I’ll keep you posted, and try not to be a bloody nuisance.
Peterp
Users browsing this forum: No registered users and 18 guests
