front hub...brake shoes
Posted:
Fri Jan 16, 2015 8:37 pm
by garynonnah
Got a problem....fitting shoes to front hub, they are sitting in position ok, cam operates them.....
but when i tried to fit to drum, they are much to tight, cannot even get them started in the drum.
GP200 Lammy....the hub is totally over hauled new everything.
Re: front hub...brake shoes
Posted:
Fri Jan 16, 2015 10:02 pm
by Storkfoot
Unfortunately, what you have experienced is pretty common. I've experienced this several times with Newfren shoes. Essentially they are too thick and bind on the drum, if you can get the drum on.
An hour or so with a file, with lots of fitting/ taking off and checking for high spots. Alternatively, take them back as not fit for purpose.
I've bought a couple of sets of Indian Makino shoes for future use, on recommendation. They don't look quite as thick as the Newfren ones although I haven't measured them. Good luck
Posted:
Fri Jan 16, 2015 10:42 pm
by garynonnah
thanks fella....they are newfren....will take them back ....and try different ones
Posted:
Fri Jan 16, 2015 11:31 pm
by Wack
+ 1 for the Makino shoes
Posted:
Sat Jan 17, 2015 12:43 pm
by peejay
+2 for the Makino shoes
Posted:
Tue Jan 20, 2015 6:59 am
by Gino_Lamberto
I have the very same problem as the OP after a complete front hub overhaul, so much so that I damaged the brand new paintwork of the 2 drum halves when they got stuck together due to binding - trying to get them apart
I will give the makino shoes a try based on recommendation
Posted:
Wed Jan 21, 2015 9:56 pm
by garynonnah
just received makino shoes, and still too tight?????? argh
Posted:
Wed Jan 21, 2015 11:22 pm
by Dimitrios_231
I hope that haven't mixed Li brake cam with GP brake shoes.
Posted:
Thu Jan 22, 2015 3:47 pm
by St George
My SIL front drum was fitted with LI shoes, this was spotted by the Classic scooter shop in Eastwood. He sold me a new pair and they were spot on.
