Re: wiring casa ignition switch problem
Hi.I've just done the same thing on a series 2 Li 125.I did away with the cut out button and fit an ignition switch instead,but I wanted to use original handlebar switch,so I followed the wiring diagram in the back of Sticky's manual but instead of using an SX/GP type handlebar switch I used the original one just for dip,mainbeam and horn.
Paul
Paul
