Inboard disc help page..............hopefully
On the last forum there was usually a few questions about inboard discs -original & remade.So (again) following on from Martin's BOK here are a few ideas I did to get mine ( a ScootRS remade type) working properly.Please feel free to add to or point out improvements, this isn't a definite guide,just what worked for me.
When I got the brake and fitted it , it was pretty hopeless, not as good as the drum brake it replaced.No matter how I adjusted it ,normal routing or reverse pull just wouldn't work properly.The quality of the casting (in my case) was spot on, as I'd asked for it in bare metal.Anyway first thing I did was change the bearings & oil seals - there wasn't any real need as they were decent enough Japanese bearings , but I like me FAGs
. .Rebuilt it , still crap.Next was change the brake shoes , in my case I went for the Scootopia type others prefer different types such as Newfren,either way you want sintered pads.These needed filing down slightly ,so that they fit loosely in the recess, you don't want to need to force them in,they should drop in.Next the disc,to help it "float" better I removed the circlip, mine doesn't rattle,thankfully.Also on the dowels the disc sits/floats on I cleaned them slightly with a bit of emery cloth, then a very very slight smear of copper grease. Put it all back together still sh*t
brake lever not springing back The only thing left was the brake operating arm,reading good things about the Scootopia arm (I'm not on commission honest!) I bought one of these ,because after this I thought feck it I'll put the drum brake back on.
ScootRS brake arm on the left Scootopia on the right.The Scootopia arm alot thicker & the spring under a lot more pressure.
ScootRS arm in situ in the hub, little or no pressure the arm can be pushed near enough all the way across.
Scootopia lever , same amount of pressure,a lot more resistance
Fitted the Scootopia arm, set it up as reverse pull,now absolutely bob on, lever returns and the brake is a joy to use & actually stops you!
To sum up, there is a cracking guide on here http://www.ilambretta.com/reverse.html on setting up the reverse pull (remember you've got to drill the cable guide on the back plate to 6mm- not as scary as it sounds, and if you want to go back to the standard routing just re-fit the cable top hat).
Remove the anti rattle circlip on the disc itself
clean the dowels & very lightly smear with copper grease
Cable wise I've used a "aircraft grade"
cable,but others prefer to use the thicker cable from scooter restos
In the picture I used a purpose bought reverse pull adjuster on the arm, this has now been replaced with a standard cable adjuster off the gear/clutch adjuster block and tapped the the trunnion that sits in the arm out to M7 so that it screws into that.
Also if reverse pull,cable tie (or whatever your preferred method is) the outer cable to the bottom of the fork tube so that it doesn't rub on the bearing cup where the forks meet the frame.
Whichever brake shoes you use make sure they aren't a tight fit,meaning you have to push them in,just lightly file the circumference till they drop in.
You can also drill out the holes on the disc if you need so that the disc floats better,I didn't need to do this.Another guide I found useful as well as the Sticky book was the Lambretta manual of performance tuning and conversions.
This is meant hopefully to give some people ideas if they're having problems with a disc brake -non hydraulic- as said at the top of the post its not a definitive guide just what worked for me
ScootRS brake arm on the left Scootopia on the right.The Scootopia arm alot thicker & the spring under a lot more pressure.ScootRS arm in situ in the hub, little or no pressure the arm can be pushed near enough all the way across.
