wiring s2 problem
PostPosted: Mon Feb 09, 2015 6:35 pm
by jghost
TV175 series 2 (1961) restore project
Put a12v system into the scoot using a new 12v loom. Engine in all running smooth.
Wired up junction box as original
All electrics working as they should apart from pilot light and horn does not work ? Confused what is the problem
Re: wiring s2 problem
PostPosted: Mon Feb 09, 2015 9:47 pm
by gaz_powell
The main brown lighting feed in the harness needs connecting into the junction box then take the double brown from the switch (live for switch and horn)and join/link the purple (side light) from switch to the double brown.(one of the browns goes to horn along with white from the switch
Yellow from switch to side light in bulb holder (plus an earth)
hope that makes sense
Gaz
PostPosted: Thu Feb 19, 2015 6:04 pm
by jghost
Cheers Gaz
This is what I have so far - I have one white wire coming from the ignition with no home to go to ?
Is this correct ?
Does speedo connect to block under white (bottom, 2nd from left) ?
Key position 1 - no lights
Key position 2 - no lights - pilot light on
Key position 3 - light on, beam works, No pilot light
Horn work in all 3 positions - Brake light working
Ta
