Tyre fitting
PostPosted: Mon Mar 09, 2015 2:54 pm
by Revvers
Hello all. Any crafty tips on fitting a new tyre onto a new rim, or is it just a matter of brute force and perseverance ??
Re: Tyre fitting
PostPosted: Mon Mar 09, 2015 3:10 pm
by Rich Oswald
Standard split rims or one piece tubeless?
Re: Tyre fitting
PostPosted: Mon Mar 09, 2015 4:03 pm
by Revvers
Sorry should have mentioned that. Split rim
Re: Tyre fitting
PostPosted: Mon Mar 09, 2015 4:37 pm
by davla
Lightly inflate inner tube. Insert tube into tyre. Wipe some tyre lube/gel around lip of tyre. Assemble rims on tyre and tighten nuts fully being careful not to pinch tube. Inflate tube which pushes tyre onto rim. Pretty easy as long as you have good rims. Buy a tyre breaker off eBay for about 30 quid which makes removal of tyres easy. Not much brute force needed.
Re: Tyre fitting
PostPosted: Mon Mar 09, 2015 5:06 pm
by Rich Oswald
A tip that I use is, after putting the two halves of the rim together and lightly inflating the tube, use a lollypop stick to push the tube in and away from the rims so that it is not nipped. Obviously you can only do this so far until the nuts start to tighten but it always works for me.
Re: Tyre fitting
PostPosted: Mon Mar 09, 2015 5:46 pm
by 911hillclimber
Washing up liquid instead of tyre lube ok?
About to do 3 rims next week.
Re: Tyre fitting
PostPosted: Mon Mar 09, 2015 5:53 pm
by Rich Oswald
I have never used any lubricant on the rims. Never needed to.
Re: Tyre fitting
PostPosted: Mon Mar 09, 2015 6:01 pm
by Revvers
Cheers guys. First attempt, inner tube squeezed out. Time to have another punt
Re: Tyre fitting
PostPosted: Mon Mar 09, 2015 6:19 pm
by davla
911hillclimber wrote:Washing up liquid instead of tyre lube ok?
I wouldn't personally, the lube/gel evaporates whereby the washing up liquid won't....having said that if it's diluted sufficiently then will probably be ok. Or as Rich says, you can probably get away without using it at all...
Re: Tyre fitting
PostPosted: Mon Mar 09, 2015 7:04 pm
by Wack
I'd rather use soap or talc as washing up liquid contains salt, that's why it's not recommended to wash cars with it.
Re: Tyre fitting
PostPosted: Mon Mar 09, 2015 10:03 pm
by coaster
Rich Oswald wrote:A tip that I use is, after putting the two halves of the rim together and lightly inflating the tube, use a lollypop stick to push the tube in and away from the rims so that it is not nipped. Obviously you can only do this so far until the nuts start to tighten but it always works for me.
A used credit card is also good 8-)
Re: Tyre fitting
PostPosted: Tue Mar 10, 2015 1:03 am
by rossclark
I've always used a round ended butter knife
Re: Tyre fitting
PostPosted: Tue Mar 10, 2015 7:01 pm
by Revvers
Sorry lads but looking at this again,surely you do have to force the rim with the hole for the inner tube onto the tyre first? Otherwise how do you get the valve to fit in the hole???
