Kickstart issue
Hi fellas,I'm new here. Can anyone help me here.have had the chaincase off my gp and now I have put it back the kickstart falls to the ground when riding along. I did undo the clutch cable and have reconnected it.the scoot kickstart fine but the gears are also bit stiff now(they were fine before) is it a clutch adjustment problem? I have also replaced the brass plunger on clutch arm.could the problem be the kickstart not positioned correctly when replacing the chaincase????? Thanks in advance
