GP200E Electrical help needed
I am currently in the process of changing the engine in my restored to standard GP200 6v battery model Electronic to an engine with a 12v AC Electrex system, looking for some help with questions below. I will be changing the rear light to a 12v Led item also, all the headset lamps to 12v.
Do I also need to change the horn to a 12v item?
Will I be able to use the existing wiring loom?
I plan on mounting 2 Cdi’s & 2 Regulators. Question is, will BGM CDi’s & Regulators be compatible with the Electrex kit?
I am very much a novice on Electrics, so any help is very much appreciated.
Thanks Tim.
Thanks Tim.
