Throttle tube
PostPosted: Sun May 17, 2015 12:12 pm
by bricky36
Hello
The throttle tube is rusted on my TV headset.
Is there a way to get this off without damaging headset.
Tried heating, just will not move.
Any ideas
Re: Throttle tube
PostPosted: Sun May 17, 2015 1:30 pm
by petemaisey
Have you a Dremel? If you can slit most of the tube and prise it apart, the bit you can't get to with the cutting wheel will probably surrender. If not you certainly will get some penetrating oil into the remains.
Pete
Re: Throttle tube
PostPosted: Sun May 17, 2015 1:54 pm
by bricky36
I dont have a Dremel (Yet).
I have sprayed loads of wd40, to no avail.
Do have grinder, but chances are I would go straight through, then be in a world of trouble.
Just read something about vinegar, maybe try soaking it in that.
But getting a Dremel does seem the way to go.
Re: Throttle tube
PostPosted: Sun May 17, 2015 2:21 pm
by petemaisey
You can also split it by cutting a spiral slot using a junior hacksaw.
Pete
Re: Throttle tube
PostPosted: Sun May 17, 2015 3:25 pm
by bricky36
Done it!
Cut a few slits with junior sprayed more wd40 and hey presto.
Thanks for help.
Re: Throttle tube
PostPosted: Mon May 18, 2015 7:59 pm
by missing lynx
try soaking it overnight in cheap full fat cola
