Ignition
PostPosted: Sun Jun 21, 2015 8:32 pm
by Kelly
Can you oil an ignition switch if so which oil should be used , its a original switch
Re: Ignition
PostPosted: Sun Jun 21, 2015 8:36 pm
by Captain Pugwash
You can WD40 is good but you can also buy electrical contact sprays that are designed to do it better.
Re: Ignition
PostPosted: Sun Jun 21, 2015 8:47 pm
by Kelly
Wd40 is that not more of a cleaning product , dont want to take out any oil / grease that still in there out , ill look into the electical oil
Re: Ignition
PostPosted: Sun Jun 21, 2015 10:40 pm
by Wob8s68
Wd40 is penetrating oil , don't use that , you need lubricating oil !
Re: Ignition
PostPosted: Mon Jun 22, 2015 9:37 am
by Donnie
I've used this to good effect in the past
http://www.maplin.co.uk/p/servisol-supe ... 00ml-jp17t
Re: Ignition
PostPosted: Mon Jun 22, 2015 7:07 pm
by Kelly
Thanks for the help
