Barrel identification
Posted:
Sun Jun 28, 2015 9:43 pm
by TS1-200
Can anybody confirm what this barrel is, I am told that its from a 64 TV200, has 2 cutouts in top fin and a shallow exhaust port, I will get a port timing rubbing later.
Re: Barrel identification
Posted:
Sun Jun 28, 2015 10:11 pm
by Adam_Winstone
The top fin notches are identifiers for SX and GP barrels so not TV200. It may well have come off a TV200 but it didn't leave the factory with it fitted.
Roll it over so that we can see the side of the inlet manifold area and we can tell you more.
Adam
Posted:
Mon Jun 29, 2015 9:54 am
by TS1-200
I thought GP SX barrels had one notch, just turned this barrel up in my quest for a standard TV200 barrel.
Posted:
Mon Jun 29, 2015 10:56 am
by hullygully
plus if it doesn't have a casting mark near the inlet then its an Indian one
Posted:
Mon Jun 29, 2015 11:29 am
by TS1-200
Or aftermarket, it was taken off years ago. just spoke to the guy that had the barrel, and he is positive it came off of an early untouched TV200.
Posted:
Mon Jun 29, 2015 2:06 pm
by Adam_Winstone
Nope, both SX and GP 200 factory barrels have the 2 notches (one either side) taken out of the top fin and both have the number stub with number. The GT barrels do not have the notches but they do have the number stub and number.
Quite right that many aftermarket 'standard' 200 barrels do not have any markings to the side of the manifold area but have retained the notches in the top fin. Many Spanish barrels do not have notches or stubs, whilst others do... the last Austisa barrels having a different base gasket profile.
Most genuine SIL 200 barrels will have the SIL 'S' logo to the side of the side of the manifold area but it is not on a stub.
As far as the porting goes, this looks (from memory) like the standard GP200 porting, with 20mm high exhaust and 18mm deep inlet. The SX200 barrel, which has same part number and same notches/stub as GP200 commonly has 18mm high exhaust and 18mm deep inlet (early Jet 200 has these port timings). Both the early and late versions of the TV200 have the deeper inlet port, which this does not, and only the exhaust port changes from wide/shallow to tall/narrow.
As this barrel does not have the identifying marks of a TV200, nor the porting of a TV200 barrel, I'll let you decide what it is... or isn't. Please note that this is not to have a go and the vendor, just to say that at some stage during this bike's life the barrel was replaced, which makes perfect sense if you say it came off a genuine early TV200, which had the 'ring-breaker' nickname for good reason. If you broke a ring because of a porting issue, would you get the same problem barrel rebored or would you replace it with a barrel that resolved the issue and could give good service for the remainder of the bike's lifespan?
If you happen to be on the 'other' forum also, do a search on both sites as the porting and identification of 200 barrels has been covered previously, with photos and port maps to illustrate the differences.
Adam
Posted:
Mon Jun 29, 2015 5:21 pm
by Adam_Winstone
Not only did this come up on a thread before... but it was you asking and me answering:
viewtopic.php?f=10&t=2105&hilit=factory+barrel
Posted:
Mon Jun 29, 2015 11:04 pm
by TS1-200
Thanks Adam, as you know I have been looking for a standard TV 200 barrel, I must admit as soon as I saw the fin cut outs I was a bit unsure, I have just fitted a standard spec SX200 barrel to my TV to replace my badly ported barrel, and it has improved bottom end pulling 2 up no end, not concerned with outright performance too much, just looking for gentle touring 2 up.
