Found an air leak! :-( Now what?
Still building the GT186 slowly and done a leak down test
It's hard to tell though exactly where its coming from? ie its looking like its coming from the upper cylinder stud on the mag side.
However, it's not coming via the base it's between the 1st and 2nd fin.
So, is it a leak via the stud and travelling up past the base gasket to the next spot and fixing it simply means removing the stud and replacing with loctite added to ensure no leak or is there something else going on?
Any help appreciated.
https://www.youtube.com/watch?v=gWxEDSZ_VCg
