New member with electrical problems
So today was the first chance I've had to have a good look at it and see what's needed.
I quickly checked the fuel, plug and and filter and tried to start it up.
I'm guessing from cold the way is: Petrol on. Full choke no throttle and it should fire.
Well it didn't, it wasnt until the third kick that I remembered the dodgy set of keys given to me.
There seems to be 3 clicks to the ignition, I turned it 3 clicks kicked it over and it fired first time! I left it idle on the choke for a minute and then turned it off. It idled well and revved pretty cleanly with a little white spoke and lovely fumes of the two stroke.
While it was running I grabbed my hat and thought I would quickly take it up the road for my first ever ride on a Lambretta.
It jolted into first gear and off i went, after spinning my left hand like a man possessed I managed to get it into all of the gears before I ran out of road.
On the way back down the road I thought I would try the brakes. Haha brakes he says. All I got was a massive knocking sound from the headset and a progressive slowing that really cant be called braking.
But all in all pretty pleased still.
So the first set on numpty question's for you all.
The 3 stages of the ignition is that normal or just a worn out ignition?
The lights work, but are only off or on! Should it have a dipped beam? Or are the lights that bad dip would be dangerous?
