Best Spare Wheel Carrier for Sip Tubelss Rim
PostPosted: Thu Nov 26, 2015 5:46 pm
by Granty
Guys -- as above whats the thoughts on the best spare wheel carrier for sip tubless & would a sip tubless rim fit on a normal legshield spare wheel carries on series 2?
Re: Best Spare Wheel Carrier for Sip Tubelss Rim
PostPosted: Fri Nov 27, 2015 2:15 pm
by Rich Oswald
Not sure about the best, it's just personal choice, but on either legshield or rear I think you will need longer studs to fasten the wheel to, I certainly did on my rear one.
PostPosted: Fri Nov 27, 2015 2:59 pm
by Adam_Winstone
I have long cylinder nuts fitted to my carrier studs then a washer, then the spare, then bolts trough from the outside into the long nuts. I've not had the wheel come loose to date. :)
Adam
PostPosted: Fri Nov 27, 2015 4:23 pm
by Granty
Adam_Winstone wrote:I have long cylinder nuts fitted to my carrier studs then a washer, then the spare, then bolts trough from the outside into the long nuts. I've not had the wheel come loose to date. :)
Adam
Thanks Boys -- this looks like the best option for me I think -- thanks for the heads up - G
PostPosted: Fri Nov 27, 2015 6:55 pm
by Adam_Winstone
Soz, I should have pointed out that I actually use alan key type bolts on the outside, rather than hex head, so that they seat correctly in the SIP rims.
