Rear hub oil seal replacemet...help
Removed the rear hub on my series 3 LI150 Special to find everything covered in oil.
I assume the oil seal has failed.
Can this be replaced with the bearing and shaft in place or does everything have to come out including the bearing to replace the oil seal.
