Page 1 of 2
S3 Fork Link Pivot Bolt Removal
Posted:
Sun Jan 31, 2016 4:02 pm
by skip123
Stripping down S3 forks for refurb and repaint. Have removed one of the fork link pivot bolts without a problem. The other, despite having the nut loosened and being free to turn in the fork boot, refuses to come out. Have tried a bit of gentle persuasion with a hammer(!) and pressing the bolt out in a vice but it refuses to budge.
Have I missed something? Any ideas on what's going on or what else I can try to get the bolt out?
Thanks.
Re: S3 Fork Link Pivot Bolt Removal
Posted:
Sun Jan 31, 2016 4:19 pm
by Scooter Paul
I have had the same issue recently with a Vega. One side came out clean as a whistle the other seized solid. The bolt will be seized in the inner bush so even if it turns what you are experiencing is the outer bush turning in the link. If you have the time try immersing the whole assembly in diesel or something for days. If not cut the ends of the bolt off flush with the outer fork and the drill the bolt enough to free the link. Don't increase the size of the hole in the leg though.
Paul.
Posted:
Sun Jan 31, 2016 5:30 pm
by CHRIS in MARGATE
Have had exactly the same. Did a fork rebuild last year for somebody. Normally a reasonably quick job. One out in minutes; the other would not play ball. Soaked in diesel to no avail.
As said ...Drill out. You need good brand new drill bits and it takes some time. Pig of a job !
Posted:
Sun Jan 31, 2016 6:19 pm
by Meds
I had the same problem,
Used a vice and a couple of kettles of boiling water.
Posted:
Sun Jan 31, 2016 8:23 pm
by CHRIS in MARGATE
If you can get it moving in a large engineering vice with a socket one side that can freely accommodate the other side of the bolt all well and good. Try moving it back and forth to break the corrosive seal. If not its drilling I'm afraid.
Posted:
Sun Jan 31, 2016 8:52 pm
by MickYork
I welded a bar onto the bolt head so it could be pulled easier, maybe the heat also helped.
Posted:
Sun Jan 31, 2016 9:00 pm
by soulfecker
CHRIS in MARGATE wrote:If you can get it moving in a large engineering vice with a socket one side that can freely accommodate the other side of the bolt all well and good. Try moving it back and forth to break the corrosive seal. If not its drilling I'm afraid.
You do need a good vice at times. I thought I had when this happened!
Had to drill it out eventually, but without a vice to hold it.
Paul
Posted:
Sun Jan 31, 2016 9:19 pm
by CHRIS in MARGATE
Mines bigger than yours. Lol
Wow that must have been quite scary.
Posted:
by Warkton Tornado No.1
I hope that was a vice 'on loan' from a previous place of work....
In my limited experience, they are the best kind
As for the fork link, a good, long soak in penetrant then a tight fitting bar through the adjacent empty leg on to the miscreant bolt (with nut refitted a few threads) & a good, well placed hammering can sometimes work.
Posted:
Sun Jan 31, 2016 9:41 pm
by Andyf
if the bolt is still proud, I have had some success with the methods described above. Place a large socket on a solid surface, hold the forks so that the fork-nut sits inside the socket - then hit the protruding section of the bolt. Put the nut back on the ends of the threads first to spread the load of the impact. Try really
really hard not to strike the forks.
Posted:
Sun Jan 31, 2016 9:52 pm
by soulfecker
[quote="Warkton Tornado No.1"]I hope that was a vice 'on loan' from a previous place of work....
quote]
Yes, and it's replacement was bigger, better and newer!
Paul
Posted:
Sun Jan 31, 2016 10:22 pm
by skip123
Thanks for all your replies. Looks like I've got my work cut out. And my rather more lightweight vice probably had a lucky escape!
Posted:
Tue Jul 24, 2018 9:38 pm
by neily03
Same problem here, one side came out no problems the other won't budge. Tried it in my vice but it's only small so was bending the handle. Soaking in 3 in 1 over night and will try again tomorrow otherwise I'll have to take it to work and try a bigger vice.... What a pain in the a%$e.
Posted:
Tue Jul 24, 2018 9:57 pm
by Scooterdude
I had to drill one out once despite thrashing it with a large hammer.
Oh and get a Record vice, best out there.
Posted:
Tue Jul 24, 2018 10:40 pm
by neily03
Mine is a Record vice, only a No1 though with 3” jaws and that bolt is proper stuck
Posted:
Wed Jul 25, 2018 8:30 pm
by neily03
That didn't go well
Posted:
Wed Jul 25, 2018 8:43 pm
by Storkfoot
Have you tried lots of heat from a gas torch?
Posted:
Wed Jul 25, 2018 8:54 pm
by neily03
I’ve tried some heat but only from a plumbing type blow torch. Going to take them into work tomorrow where there’s better tools and a proper torch
Posted:
Wed Jul 25, 2018 10:39 pm
by CHRIS in MARGATE
I remember this thread well.
I left the forks soaking for a couple of days in diesel.
I used a proper blowtorch.
I have an enormous vice.
After all this I drilled it out.
Posted:
Thu Jul 26, 2018 8:49 am
by HxPaul
Looks like you'll have a right job on getting it out of there,heat or no heat,because from what I can see,you've hit the bolt without putting the nut on first bending the end.
