Forks
Posted:
Wed Mar 02, 2016 5:45 pm
by steveiow
Will Serveta forks fit a series 3 Italian non chrome ring frame? Or do I need to swap for the Italian ones that are in my Spanish frame?
Re: Forks
Posted:
Wed Mar 02, 2016 10:36 pm
by Andyf
with gracious respect to original post-er
LAMBRETTA FORK LENGTH INFO
FORK STEM LENGTHS - all measurements are approx and are taken with the lower bearing track removed
Italian Series 3+ GP - has speedo/front brake cable support as seperate piece - also has cut out for headset clamp at the side of the thread (in line with front wheel)
Chrome ring
From bearing track seat to centre line of steering stop = 361mm
From bearing track seat to bottom of thread = 413mm
From bearing track seat to top of fork stem = 467mm
Non chrome ring
From bearing track seat to centre line of steering stop = 355mm
From bearing track seat to bottom of thread = 405mm
From bearing track seat to top of fork stem = 458mm
TV 200 - Chrome ring
GP
From bearing track seat to centre line of steering stop = 330mm
From bearing track seat to bottom of thread = 380mm
From bearing track seat to top of fork stem = 438mm
Italian Series2 - has welded on "loop" for speedo cable/front brake support - also has the cut out for the headset clamp bolt at the rear of the thread (at 180 degree to front wheel)
TV175 S2
From bearing track seat to bottom of thread = 412mm
From bearing track seat to top of fork stem = 462mm
LI 150 S2
From bearing track seat to centre line of steering stop = 359mm
From bearing track seat to bottom of thread = 407
Spanish
JET 200 -Large damper type - have single damper stud of 9mm diameter welded to single plate at top of fork leg. Also has cut out for headset clamp at the side of the thread (in line with front wheel)
From bearing track seat to centre line of steering stop = 358
From bearing track seat to top of fork stem = 460mm
Re: Forks
Posted:
Thu Mar 03, 2016 6:37 pm
by St George
If it helps I have a late Jet 200 SX. I bought a new remade Italian SX Headset for it. No way would it fit. Spanish forks are shorter so I am now stuck with a nice headset. I was told on my thread that a chrome ring Italian headset would fit my forks. Hope this makes sense and it may help answer your question.
Regards Colin
Re: Forks
Posted:
Thu Mar 03, 2016 11:51 pm
by steveiow
Thanks , so my interpretation is that a Spanish fork is 358 mm and a non Chrome ring fork is 355mm therefore it should have enough thread to fit. I know that these forks didn't fit a chrome ring frame as they were tried in one and came up short.
