Timing
Bit of advice please.have removed crank from gp200.i marked the stator position when I removed it but the Conrod was seized on its bearing so not sure what position piston was at when it came out.when I replace the stator in its original position does it make any difference what position the piston is at when I put the flywheel back on,will I affect timing.
