Stand Spring Length
PostPosted: Wed Apr 20, 2016 8:14 pm
by Paul_from_Thornbury
Anyone know what the correct length of a stand Spring is, I've got two aftermarket ones which are slightly long as my stand droops and if I pull the stand up under the running boards with my heel the spring pops off.
From outside of loop to outside of loop mine are 110mm long.
Re: Stand Spring Length
PostPosted: Thu Apr 21, 2016 6:22 am
by Toddy
Are you sure the two main Fixing bolts on your stand are not loose as this would cause the same issue as spring length ?
PostPosted: Thu Apr 21, 2016 7:52 am
by Dimitrios_231
I don't know the correct length,sorry,the length can be different and it plays a major role.
I usually shop with a spring in my hand to compare.
These 3 springs are supposed to be from the same manufacturer.
PostPosted: Thu Apr 21, 2016 2:37 pm
Bolts are all tight
PostPosted: Thu Apr 21, 2016 2:38 pm
What are the lengths of the longest and shortest springs in the photos?
PostPosted: Thu Apr 21, 2016 3:48 pm
by Dimitrios_231
Τhis pic was taken a couple of years ago,
I can't remember :shock: :) ,
I'll check if I have any notes on my logbook,
sometimes I write down on paper some anorak pretty useless things ;)
PostPosted: Thu Apr 21, 2016 5:10 pm
by Tony Hart
Hi Paul
I just measured one that I took off my latest project and it is 105mm from outside loop to outside loop
Tony
PostPosted: Thu Apr 21, 2016 5:17 pm
by MK Monty
I'm sure series 1/2 are not the same length as series 3. But I don't know which is longer. Personally I steer clear of the stainless ones rather have a bit of rust.
PostPosted: Thu Apr 21, 2016 5:24 pm
by Tony Hart
MK Monty wrote:I'm sure series 1/2 are not the same length as series 3. But I don't know which is longer. Personally I steer clear of the stainless ones rather have a bit of rust.
The rusty one I measured came off a rusty Spanish S2. Most dealers I use don't have different springs listed for S1/2 or 3. Scooter Restorations does have a slightly longer one listed for late Indian GPs
Tony
PostPosted: Thu Apr 21, 2016 7:28 pm
by Dimitrios_231
Measured two used.
Left one 106.5.right 105.2 from outside loop to outside loop.
I always keep the left one as a spare in the toolbox .
PostPosted: Sat Apr 23, 2016 10:50 am
by hullygully
also depends on the correct welded position of the stand cross member & if your using an Indian stand as I've got some stainless steel ones where they're defo welded in wrong position grrrrrrrrr :twisted:
