rear hub oill seal
PostPosted: Mon May 02, 2016 5:57 pm
by lammydave
I've done a few of these in the past... no problem
But this one has the better of me so far... such a tight fit...
Italian layshaft, quality rear bearing and rolf seal... it's sooo tight...
Tried immersing in boiling water for a while, applied a little grease to outer and inner faces...no go!!
any ideas/suggestions would be gratefully received!!
David
Re: rear hub oill seal
PostPosted: Mon May 02, 2016 6:48 pm
by Tractorman
What about putting it in the freezer for a while.
PostPosted: Mon May 02, 2016 7:09 pm
by MickYork
i'd be more inclined to try to soften the seal. Try using an air dryer (on the seal) and get it more pliable.
Plenty of grease as well.
PostPosted: Mon May 02, 2016 9:11 pm
by a.lo
just fitted a hub oil seal today, mainly needed something to push the inner lip over the bearing edge, something not too hard or sharp. used one of those white plastic plant marker thingies it has a pointy end and curved edge, perfect!. the bearing was fitted to engine with layshaft and in bike so couldn,t use a drift.
PostPosted: Mon May 02, 2016 9:17 pm
by lammydave
Yes it seemed the inner was the issue... Will give that a shot.... Thank you
PostPosted: Mon May 02, 2016 9:39 pm
by lammydave
Thanks guys
PostPosted: Tue May 03, 2016 9:23 am
by Dimitrios_231
There is also a specific tool to fit the rear hub bearing seal,
right and top.
PostPosted: Tue May 03, 2016 2:33 pm
by a.lo
i'm guessing the two outer types go over the layshaft end?
PostPosted: Tue May 03, 2016 3:41 pm
by Dimitrios_231
Yes for tool 60405.
The other one, 59331,is for fitting the inner bearing track to the crankshaft.
PostPosted: Tue May 03, 2016 5:45 pm
by Wack
I use a piece of plastic pop bottle and grease to slide the seal in.
PostPosted: Wed May 04, 2016 5:35 am
by lammydave
Wack wrote:I use a piece of plastic pop bottle and grease to slide the seal in.
hi, Wack,... could you elaborate a bit on that for me?
PostPosted: Wed May 04, 2016 5:59 pm
by Wack
Yes, just cut a strip out of a litre bottle of pop( thinner plastic than a small bottle) wrap it around the layshaft and bearing inner track, grease and slide the seal over it with your thumbs. Once fully in, pull the sleeve out. This way there's less chance of rolling the seal and flicking the spring off.
PostPosted: Thu May 05, 2016 9:00 am
by lammydave
Wack wrote:Yes, just cut a strip out of a litre bottle of pop( thinner plastic than a small bottle) wrap it around the layshaft and bearing inner track, grease and slide the seal over it with your thumbs. Once fully in, pull the sleeve out. This way there's less chance of rolling the seal and flicking the spring off.
yes! I get it now and it is the inner part that rolls over!!
thank you!
PostPosted: Sun May 08, 2016 1:15 pm
by johnnyXS
reading this and A.LO's other thread today ,I've now got a sneaky feeling that I fitted my oil seal the wrong way round last week :?
Dayum ..........I'd better go check :roll: ......and I was feeling all smug up until now
PostPosted: Sun May 08, 2016 6:00 pm
by rossclark
Oilseal rule - Spring always faces the thing you want to stop getting out or the highest pressure
