help needed with fuel problem please. NOW SORTED WITH THANKS
PostPosted: Sun Jul 06, 2014 10:19 pm
by 59 lammy boy
Scooter starts okay on choke and runs okay. Push the choke in the engine has warned up and it just stops. Won't run without choke
Help please
Re: help needed with fuel problem please
PostPosted: Mon Jul 07, 2014 6:27 am
by Toddy
Have you had the carb of and cleaned the jets ? sounds like a blockage from your short explanation
PostPosted: Mon Jul 07, 2014 3:52 pm
by paul213
is it a std carb just had a similar problem on a jet turned out to be a blockage in the brass restricter next to the mouth of the carb (on the left as you look straight at it) that feeds air to the pilot circuit prodded it out with a piece of 1mm welding rod ,runs fine now
PostPosted: Mon Jul 07, 2014 4:24 pm
by Paulnobodyimportant
Out of the blue, that happened to me last Thursday on a 22mm dellorto. Suspected a dirty pilot jet and that's what the problem was.
So, cleaned pilot jet with a blast of carb cleaner. And for good luck, cleaned rest of carb jets and holes with spray carb cleaner. Runs OK now.
PostPosted: Tue Jul 08, 2014 11:42 am
by bigbthesoulman
Carb problem,try a good clean up,if not could be starved of fuel ,ok with choke not without check flow from tap
PostPosted: Tue Jul 08, 2014 3:08 pm
by 59 lammy boy
Thanks for all your advice
Now sorted. Just took carb off and got the air line to it. Perfect
