SIP Speedo freezing
Hi all,
I need some input on this........
My SIP speedo has started to freeze and show 124mph, rpm needle creeps up to 12000 rpm then all goes blank except the frozen temperature reading.
I've searched for some info, older posts on other forums seem to indicate it is an issue of using non resistor spark plugs.
Thing is, I have a resistor plug fitted, unless of course my plug is starting to fail.
Only thing that has changed from my old set up is I have fitted a Casatronic ignition, converted to DC, of course.
I did change the pulse settings in the speedo for the new system too.
Just looking to find out if these symptoms have been experienced by anybody else before I start diagnosing the problem.
Any info much appreciated.
Cheers.
Cheers.
