Page 1 of 2
Tool box lock
Posted:
Sun Sep 04, 2016 10:35 pm
by jonoy
Can you buy the small screws and nuts
which hold the lock to the door separately
if yes where from
Re: Tool box lock
Posted:
Sun Sep 04, 2016 10:49 pm
by burnside
Normally riveted on aren't they?
Re: Tool box lock
Posted:
Sun Sep 04, 2016 11:13 pm
by Norrie Bodge
burnside wrote:Normally riveted on aren't they?
I did to both on my GP & S2?
Re: Tool box lock
Posted:
Mon Sep 05, 2016 7:53 am
by rossclark
Definitely should be rivets. You'll get them from Scotopia or Restos.
Re: Tool box lock
Posted:
Mon Sep 05, 2016 8:45 am
by HxPaul
Definitely should be riveted,but I've got mine attached,both series 2 and series 3 with nuts and bolts.
Re: Tool box lock
Posted:
Mon Sep 05, 2016 1:21 pm
by Knowledge
Many years ago I riveted one on a DL I was restoring, and as the rivet popped, the riveting gun jumped and the sharp cut end of the rivet stem scratched freshly painted tool box door.
This is called learning lessons the hard way.
Re: Tool box lock
Posted:
Mon Sep 05, 2016 1:28 pm
by EddieStone
I secured mine using nuts and bolts and they keep coming undone! Also they look insecure as all you need is a small screwdriver and you can have access to my oil, an oily rag and my precious measuring jug....
Re: Tool box lock
Posted:
Mon Sep 05, 2016 1:58 pm
by HxPaul
EddieStone wrote:I secured mine using nuts and bolts and they keep coming undone! Also they look insecure as all you need is a small screwdriver and you can have access to my oil, an oily rag and my precious measuring jug....
I use nylock nuts and they never come lose.
Re: Tool box lock
Posted:
Mon Sep 05, 2016 2:51 pm
by EddieStone
For the OP, I think I used 3mm bolts and nuts. Should have used 3mm bolts and nylock nuts....
Re: Tool box lock
Posted:
Mon Sep 05, 2016 4:50 pm
by foremanbob
I used the button heads to look like rivets with nyloc nuts....
Re: Tool box lock
Posted:
Mon Sep 05, 2016 9:45 pm
by citydaz
I also used 3mm button head bolts, but with 2 nuts and thread lock. no problems after months and it looks quite professional,if I say so m yself!
Re: Tool box lock
Posted:
Tue Sep 06, 2016 5:30 am
by Digger
Agreed that they look the business.
Re: Tool box lock
Posted:
Tue Sep 06, 2016 10:07 pm
by jonoy
Where did you get them ?
Re: Tool box lock
Posted:
Tue Sep 06, 2016 10:53 pm
by EddieStone
Thread winner. They look ace.
Re: Tool box lock
Posted:
Tue Sep 06, 2016 11:46 pm
by jonoy
These are what I have
But they have vibrated loose and I have lost one
of the nuts
Re: Tool box lock
Posted:
Wed Sep 07, 2016 9:24 pm
by citydaz
I got them from these guys on fleabay - Tek Hardware, Kays Fasteners
Re: Tool box lock
Posted:
Wed Sep 07, 2016 9:25 pm
by citydaz
jonoy wrote:These are what I have
of the nuts
did you use washers?
Re: Tool box lock
Posted:
Thu Sep 08, 2016 9:36 pm
by jonoy
Yes used washers
The vibration has loosened them
Re: Tool box lock
Posted:
Fri Sep 09, 2016 10:41 am
by Marty ULC
jonoy wrote:Yes used washers
Did you use threadlock or nyloc nuts? I used nyloc nuts on mine and they haven't come loose after a few thousand miles.
Re: Tool box lock
Posted:
Fri Sep 09, 2016 8:50 pm
by bookertmgs1
