Sprocket height and chain alignment
I changed my front sprocket from 18 to 17 tooth last night.
I knew that I'd aligned front and rear sprockets well so I compared new and hold heights i.e. from the machined Base to the upper flat surface of the teeth.
There was 0.8mm difference. Easily sorted by fitting a new shim under the clutch sprocket that was 0.8mm thinner that I had.
Anyway, it made me wonder if it really matters as I hear of folk changing sprockets ad hoc but don't get the impression that they're aligning the sprockets when they do.........
Also was I just unlucky in having such a big difference? I can't remember where I got the 17 from but the 18 tooth is from 'a reputable SIL dealer'.
Does it matter?
Does it matter?
