SILGP wrote:Hi , I've just fitted a spark plug temperature gauge. I started it up to see it working but the engine started racing so much that the scooter was moving around on the stand with the vibration. The only thing I did engine-wise was to remove and refit the spark plug to fit the sensor ring.
I'm baffled - anybody got any ideas ?
Coincidentally perhaps with your issue, I set about having a go @ this pressure testing malarkey as I happened to have a 20 x 2.25 inner tube with punctures so that is where I made the cut & fitted it on to the inlet & exhaust pipe (quite a stretch!) Unlike other Forum User’s versions, I kept the Schrader valve in & just put some air in...So my version is probably the cheapest of the cheap because I found the whole bike in the street!
However, the only point I found to leak was @ the spark plug!
A brand new plug & seal leaked, but I must mention that the cylinder head has a threaded, ‘solid’ insert that does result in a raised shoulder.
I managed to cure the leak there by refitting another plug with one of those solid copper washers that you get specifically for that purpose.
It may be all that you need! BTW under-plug heat sensors are notorious for leaking in the air-cooled VW World as well as ours...
If you get stuck, I’ll send you a washer that I speak of FOC. Let me know, eh?
(Hi Kenny!
