A bit of advice....again
Posted:
Sun Feb 05, 2017 9:24 pm
by Charliebubble47
Hi gents
I fired up my scoot for a blast along the back lanes yesterday, kicked over no problems and warmed up for about 10 mins. Took her out but as soon as I changed down the gears it started to bog down and then it stalled and wouldn't kick over I pushed it back to my garage and checked the spark plug, which was black and oily, so I changed it for a new. I had one of those inline fuel filters on so I removed that and renewed the fuel line, changed the fuel and swapped the carb over for a spare jetex I had.
So I today I fired her up, no problems let her tick over for a good 20 mins with no problems, took her out but as soon as I got into 3rd gear bogged down again and conked out. Pushed back to the garage but she wouldn't kick over. Spark plug black and oily. I checked the fuel flow rate when I changed the fuel line.
It's a electronic ignition if that makes a difference
Any advice will be most grateful
CB
Re: A bit of advice....again
Posted:
Sun Feb 05, 2017 9:29 pm
by Fast n Furious
The content of your post suggests the engine is finding it hard to breath. Check your air filtration. (Have you left anything under the seat that could block the breather scoop?)
Posted:
Sun Feb 05, 2017 9:34 pm
by MickYork
Need more info'.
What scoot is it ?
Is it kitted ?
What carb' and settings ?
Open mouth or filter ?
Advance/retard ignition ?
What is ignition set at ?
etc
etc
Sounds like your bogging down .....too much fuel to air ratio...
or it could be stator breaking down........cooling.....then working again.
Have you got a Sticky's manual ? worth getting one and having a read.
Posted:
Sun Feb 05, 2017 10:12 pm
by Charliebubble47
Fast n Furious wrote:The content of your post suggests the engine is finding it hard to breath. Check your air filtration. (Have you left anything under the seat that could block the breather scoop?)
It breathes through a ram air remote filter and there isn't a air scoop it's Spanish and used to breathe through the tool box but I will check the filter for cracks or a blockage
Posted:
Sun Feb 05, 2017 10:25 pm
by Charliebubble47
MickYork wrote:Need more info'.
What scoot is it ?
Is it kitted ?
etc
etc
Serveta lynx 125 but with a 186 kit on
22mm jetex carb don't know what the jets etc are but will have a look tomorrow and it has a ram air remote air filter and a standard clubman exaust
Don't know the advance/retard ignition or what it's set at
I have a spare stator so will look at putting that on if all else fails
Thank you
Posted:
Sun Feb 05, 2017 11:31 pm
by MickYork
try it without the air filter.......
Posted:
Mon Feb 06, 2017 12:19 am
by Charliebubble47
MickYork wrote:try it without the air filter.......
Will give it a go tomorrow and see what happens
Out of curiosity what would be the best set up on the carb,
just looking at stickys book and my carb is set up for a gp150
Slide:7895-2
Atomiser:5899-4
Main jet:118
Pilot:45
Starter jet:50
Would this be causing the problems
Posted:
Mon Feb 06, 2017 12:38 am
by coaster
Are absolutely certain that your choke is closing properly? there should be a bit of slack at the carb end when it is in the off position.
Posted:
Mon Feb 06, 2017 12:50 am
by Charliebubble47
coaster wrote:Are absolutely certain that your choke is closing properly? there should be a bit of slack at the carb end when it is in the off position.
Will have a look at this tomorrow
Posted:
Mon Feb 06, 2017 6:50 am
by lammydave
make sure your petrol tank cap is breathing
Posted:
Mon Feb 06, 2017 7:42 am
by CHRIS in MARGATE
Agree it sounds like an inability to breathe. What has changed ? Is this a new fault or has it always been like this ?
Posted:
Mon Feb 06, 2017 10:56 am
by HxPaul
Charliebubble47 wrote:MickYork wrote:try it without the air filter.......
Slide:7895-2
Atomiser:5899-4
Main jet:118
Pilot:45
Starter jet:50
If its a 186 top end,your carb needs setting up as a 200
Slide:7895-1
Atomiser:5899-2
Main jet and pilot may need altering,but they will get you running and you can fine tune them from there.The choke jet is the same in a 150 carb or 200 carb.
Posted:
Mon Feb 06, 2017 11:14 am
by EddieStone
Sounds like a choke fault to me.
Posted:
Mon Feb 06, 2017 12:03 pm
by Rich Oswald
lammydave wrote:make sure your petrol tank cap is breathing
+1
Posted:
Mon Feb 06, 2017 12:28 pm
by missing lynx
when was the last time you cleaned the air filter?
Posted:
Wed Feb 08, 2017 11:45 pm
by Charliebubble47
Cheers gents I think I've got it beat......sticky choke.
There was no slack on the choke cable so slacken it off and checked the choke action when I had the ail filter off to check that and for good measure I checked the fuel cap breather it seamed ok but I gave it a goo dream out with a strand of copper wire.
I gave it a blast out last night with no apparent problems....fingers crossed and all
Once again thanks for all the sound advice
CB
