Piston to barrels sizes
Hi
I had a barrel rebored and a meteor piston supplied with it around 20years ago it has never been fitted and stored dry and is still as good as the day it was done.
I fitted it a few weeks ago never ran well when you could finally get it to start ! so I stripped it down after around 10 miles the piston looks like it's done 20,000 miles ? ( blow pass the rings )
I measured the bore with a bore gauge and it reads 57.8 all over !
The piston is stamped 57.8
The piston ring gaps are around 20" thou
The piston skirt in bore is around 6" thou
It shows signs of piston slap
On a 4th oversized what actually is 57.8 the barrel or the piston ????
Have I just got a badly made piston or has my barrel been over bored ?
Thanks for any help it's much appreciated
Ps no I don't take any measurements before running
