petrol tap flow rate - which holes??
Fitted an OMG side exit petrol tap at the beginning of the year- never checked the flow rate
......anyway had a few issues in Italy, just going through a few things now we're back.Checked the flow rate with the tap in the "on" position and also on reserve, 3/4 of a pint in a minute.My understanding is that a fast flow is 1 pint in a minute or more.Anyway took it apart, can you make the holes bigger to improve the flow, if so which ones all of them? I like the idea of a side exit tap and would like to persevere with it , saves having to run the pipe around the bump stop and up an over (GT200 kit carb on the right hand side).If so is it just a case of slowly making them slightly bigger with a drill bit? Appreciate your help
Pictures below -hopefully
top holes from tank into the tap
http://i.imgur.com/OyJ435k.jpg
exit holes -all 3 need making bigger, I'm assuming one is reserve?
http://i.imgur.com/IIVVHJ3.jpg
