Fork spring stops/top hats?
PostPosted: Wed Jul 19, 2017 11:57 am
by AlG
I am rebuilding a set of GP forks, but for a number of inconvenient reasons will be using SX/TV disc links with fixed ball rods. Can anyone advise which top hats/spring stops to use? I currently have double thickness GP type fitted, but wondered if I needed to use the SX/TV type plastic top hat spring stops instead? Are GP and SX/TV forks the same internally where the spirng stops fit?
AlG
Re: Fork spring stops/top hats?
PostPosted: Wed Jul 19, 2017 12:26 pm
by Warkton Tornado No.1
Coincidentally with you, I’m building some forks for a mate using (non SIL Indian) GP forks fitted with (non OEM) fixed ball-end piston rods. Gawd knows where he bought 'em, but they needed turning down to fit the link cups & my fork tool has needed modification to fit the slot in them for compression!
As he also supplied the top hat type nylon stops, that’s what I’m using as I cannot think that the GP type offer any advantage, allowing the steel rod to wear the stop that much quicker as there is less bearing surface.
I’m also not convinced that double stops help the handling, though they obviously increase spring pre-load. On the other hand, TV175 S2 springs do improve the ride.
For the record, I will be using thick top buffers & medium bottom buffers.
