Tilted front wheel question
Recently got round to replacing the front disc pads in my SX200 lookalike (SX 175 with most of the bits)
When I'd got it all back together and on the road, I happened to notice that the front wheel, viewed from the the front, looked slightly tilted.
I measured the two distances from the nearest part of the tyre to the forks, and the result was that the distance was 20mm on the right hand and 27mm on the right. Went back and checked that I'd assembled the hub correctly, and it seems OK.
What would be the most likely cause of this? Bike's running fine and no handling problems, but it can't be right?
