FRONT HUB
I have replaced all the internals of the front hub and used new fork links, no problems
As i fit the hub to the fork links the fork legs move slightly inwards as i tighten the dome nut. is this normal or should i use spacer washers to stop the fork legs moving inwards even though spacer washers are not shown in the parts book
cheers
cheers
