Reproduction Front Disc Brake
PostPosted: Sun Dec 10, 2017 11:21 am
by Cosmic Wizard
Good morning all.
Has anyone bought and fitted the reproduction SX/TV front inboard disc brake?
I'm looking at buying one, but would like to know if it's worth buying, or shall I try and find an Innocenti unit and rebuild it?
Thanks in advance.
Jim :D
Re: Reproduction Front Disc Brake
PostPosted: Sun Dec 10, 2017 11:31 am
by Angry Bloke
From experience,the repro one can need more fettling time than it takes to rebuild an original and they are not much cheaper .
I would go for an original one
PostPosted: Sun Dec 10, 2017 11:46 am
by gizmo
Angry Bloke wrote:From experience,the repro one can need more fettling time than it takes to rebuild an original and they are not much cheaper .
Agree totally, I would try and source an original and as Mr Angry says, not much difference in cost
PostPosted: Sun Dec 10, 2017 11:56 am
by Watfordwhite
I would try an original if you can find one, however I have an ScootRS repro on my S2 and it works a treat. Use sintered pads and a reverse pull. Excellent stopper.
PostPosted: Sun Dec 10, 2017 2:21 pm
by AlG
I recall that the levers need checking on repro's or replacing with an original lever.
PostPosted: Sun Dec 10, 2017 4:03 pm
by HxPaul
Watfordwhite wrote:I would try an original if you can find one, however I have an ScootRS repro on my S2 and it works a treat. Use sintered pads and a reverse pull. Excellent stopper.
+1
PostPosted: Sun Dec 10, 2017 6:33 pm
by St George
I too have the ScootRS with sintered pads, no issues and well made and it's new. Fitted very easy. Considering reverse pull.
PostPosted: Sun Dec 10, 2017 7:06 pm
by Storkfoot
There is an Italian, Tino Sacchi??, reproduction version. Armandos, amongst others, sell it. I have no personal experience of one but, given the ScootRS one is no longer being remade, this may be your only option to an original.
PostPosted: Sun Dec 10, 2017 7:24 pm
by gaz_powell
Saigon Scooter Centre do them
PostPosted: Sun Dec 10, 2017 8:20 pm
by Cosmic Wizard
Thanks all, just the sort of info I was after.
Thanks for the replies :D
PostPosted: Mon Dec 11, 2017 3:13 pm
by drivera
AlG wrote:I recall that the levers need checking on repro's or replacing with an original lever.
Yes the spring on the actuating lever is not as strong as on original campagnolo ones , scootRS did modify theirs but originals are better if you can get hold of one
PostPosted: Mon Dec 11, 2017 9:19 pm
by Watfordwhite
From memory I thing Scootopia also do a brake cam upgrade, but I've never needed it on the ScootRS one I have. Just got another one from EBay for the S1 rebuild.
PostPosted: Tue Dec 12, 2017 8:15 pm
by Stevepshipley
From my experience, in board discs are not a good as a well set up drum brake. Jmo
Cheers Steve
