Series 1 shocker length
Posted:
Mon Jan 15, 2018 10:41 pm
by rumiman
Just building a series 1 with reed valved avanti, only a that's cock of clearance frame to reed block at 31.5mm "&series 1 shocker length" , has anyone runa series 1 with a shorter length shocker or will you do clearance be an issue ? Mb clubman exhaust .
Re: Series 1 shocker length
Posted:
Mon Jan 15, 2018 10:42 pm
by rumiman
Gnats cock of clearance not that's cock.
Posted:
Mon Jan 15, 2018 10:44 pm
by rumiman
Bloody predictive thingy !!! Was asking if "ground clearance" was likely to be an issue.
Posted:
Tue Jan 16, 2018 9:52 am
by HxPaul
I had the same problem with the rear shocker on my series 2,in the end I used a series 3 shocker (305mm).I've run the scooter for a year without a problem.So if anybody wants a Scootopia adjustable rear shock for a series 1 or 2,I've got one cheap,never been used.
Posted:
Tue Jan 16, 2018 9:53 am
by Tractorman
Could try offset engine mounting cones.
Posted:
Tue Jan 16, 2018 12:19 pm
by Watfordwhite
Yes, my S2 runs a 225 Rapido & reed motor. I used a S3 rear shock and offset cones. No problems.
Posted:
Tue Jan 16, 2018 1:40 pm
by rumiman
Thanks for the replies, appreciated.
