scootopia petrol tap modification
Posted:
Sat Jan 20, 2018 10:36 am
by gaz_powell
The low reserve is a known problem on these taps, i've modified mine with a longer brass tube.
I had to buy 300mm of tube so if I've got a bit spare if anyone wants a piece.
First come first serve, I will be keeping some spare for myself for future.
Let me know what length you want
Gaz
Re: scootopia petrol tap modification
Posted:
Sat Jan 20, 2018 9:23 pm
by ToBoldlyGo
Got to admit the thought of having an unknown amount of not very much reserve does worry me. But it's probably easier to buy a regular OMG fast flow tap instead.
Posted:
Sat Jan 20, 2018 10:51 pm
by gaz_powell
Good taps apparently, simple fix for a bigger reserve. I just set mine up with pipe same size as the OMG ones.
Not fitted to anything yet
Posted:
Sat Jan 20, 2018 11:19 pm
by Nigel. S
Been caught out by this too. Flip to reserve thinking it'll get me home only for the dreaded "bluurrggghhh" and dying a few miles later. Should've noticed when I fitted it.
Posted:
Sat Jan 20, 2018 11:48 pm
by HxPaul
I think it s been said before that the reserve on the scootopia petrol tap is quite adequate if your running a long range tank.
Posted:
Sun Jan 21, 2018 2:14 pm
by Hammer RB230
Gaz
Ive been thinking about modifying my Tap, which I like apart from the reserve problem. I just haven't had time to source some suitable tube.
So yes I would like some please, unsure what length, happy to go with what you used. Its fitted to a standard tank if that helps.
Posted:
Sun Jan 21, 2018 3:11 pm
by gaz_powell
No problem - mine new one is cut 60mm PM me your address or i'll be at AGM next week so could take it there.
